jamhead
So, what's the better bass trap...
1) 4" of OC703 straddling a corner with an air gap behind (24" wide face on the trap)
2) Superchunk of OC703 cut into triangles (24" wide face...17" sides to corner).
3) 4" of OC703 next to a corner with a 1" air gap behind - where one side of the trap would fit into the corner.
I have three wall-to-wall corner bass traps I'm going to build (I have one done...a superchunk OC703).
Cost is always an issue. I've looked into Roxul Safe n Sound, which supposedly works well (denisty is 2.5lbs) for superchunk bass traps but isn't rigid at all...so may not work for "standard" absorbers. One trap, behind a door, will have to be next to the corner (Description #3 above).
The rigid panels may be more flexible in that I could use them for other treatments if needed.
Or, would it be better to have paper in front of the bass traps...similar to FRK?
