CNC JBL 2397 horns
Wardsweb
Renaissance man
Here is a pic from earlier today as some 1" African bubinga was being machined into custom horns. The holes you see are where the bolts go through to hold the vanes.
Yesfan70
I'm famous now bitches! vvvvv
Oh goodie, goodie! Another project.
Looking forward to your progress on this.
Very interesting! So where was that machining being done? Is that a regular manufacturer of these horns, or is this a custom one-off thing that you've arranged? That would be very cool to watch.
Botch
Wardsweb, do you have a home CNC setup?? If so, :bow-blue: :bow-blue: :bow-blue:
Wardsweb
Renaissance man
PaulyT and Botch - alas no CNC at home but about 10 minutes down the street. It is a plastics supplier/fabricator, but they will CNC anything. Their CAD designer is into audio and wants to hear some classical music when the new setup is done. He is also going to design and cut some stands out of the same wood. These will sit on top of my JBL C-50 Olympus, along with the JBL 2405 tweeter.
Botch
Suh-WEET!!! :music-rockout:
Wardsweb
Renaissance man
Here is a finished set with the custom CNC billet vanes. The wood is just as it was coming off the CNC. It has not been sanded yet. So it will only get better.
Wardsweb
Renaissance man
Here is how they go together. They will actually bolt together with inserts in the top half of the horn for the bolts to thread into.
Wardsweb
Renaissance man
Here is a look head on. Still need to sand, some Danish oil, polish the vanes and make some stands.
Where is the design of the horn shape coming from?
Wardsweb
Renaissance man
Are those Peziolectic Tweeters?
They are compression driver horns. In place of what you think would be a horn, they use a slot with an aluminum diverter in it.
Wardsweb
Renaissance man
Ok sanding was a lot more of a task than I had anticipated. The very hardness that made machining nice, makes sanding difficult. I ended up using 120 grit on a random orbital palm sander to get the paper to even cut. I then hand blocked a little with some 320. Running your hand over it, you would think it had been finished in 600 grit.
Here is a picture as the first coat of Danish oil was going on.
