Introduction
I have created and contributed to many online forum threads discussing acoustic treatments in rooms. Very often others will ask, “Where do I place my absorbers in this room?” or, “If you only put up one absorber, where would it be placed?” The answers to those questions are not always easy to answer. Most of my advice comes from decades of experience and trial & error in studios, homes, theaters, and other rooms I have worked in, as well what I have learned from dozens of reference books and discussions with some the leading authorities on acoustics. Here is a short article discussing what I consider to be some important things to consider when treating a room.
Types of Acoustics Issues
Every acoustical environment is fraught issues caused by reflected and absorbed sound. There are issues caused by standing waves which generate nulls, or absence of sound, at certain bass & lower midrange frequencies and nodes, or increased output, at other bass & lower midrange frequencies. There are also issues with reflected sound in the midrange and treble frequencies causing the stereo imaging from the speakers to suffer. These higher frequency reflections also cause the sound to lose detail and seem distorted.
This article will discuss the mid to high frequency reflections that tend to hinder detail and stereo imaging.
LEDE
The LEDE room (Live End Dead End) is a well thought-out approach to treating a room for stereo reproduction. The concept is based on preventing all first order reflections from the front of the listener and diffusing all rear reflections. The most important reflections to treat in the midrange are the first order reflections that arrive at the listener’s ears less than 9mS, or so, after the initial sound from the speaker reaches those same ears. Any reflected sound that arrives in that initial 5mS to 9mS window will not be interpreted by the brain as an echo. Instead, it will be interpreted as part of the original signal and the listener will hear the audio as smeared, fat, lacking detail or fuzzy (see charts 1 & 2).
LEDE
