Axiom 1500 Amplifier:
TitaniumTroy
Looks like this amp has a lot of power as it doubles down from 8-4 ohms. However I don't see a spec. for it's current rating, might be a good choice for people who need lots of power with inefficient speakers like my Magnepan's.
http://www.axiomaudio.com/1500-amplifier
"Look beyond the amplifier's rated watts-per-channel output to its power supply: home theater enthusiasts know that it takes strength and suppleness to deliver power to multiple channels all together, and the 1500 amplifier delivers both. By combining a class-D amplifier with a toroidal transformer and a large storage capacitance, you have the muscle you need to deliver power where it's needed, when it's needed. You won't hear distortion or compression: just clean, endless sound that never clips, overheats or runs out of headroom.
The massive analog power supply partners with the Axiom Digital Amplifier to exceed 90% efficiency: compare that to the typical Class A/B design you find in most amplifiers that waste nearly half the output from the amplifier in heat! Think about the numbers: a typical wall plug is capable of producing 1800 watts on a regular 15 amp circuit. The Axiom Digital Amplifier is so efficient, you can easily achieve 1500 watts of total output: approximately double what a Class A/B design can provide. What does that transfer into in your system?"
8 Ohms
4 Ohms
Max Output per Channel One Channel Driven
325
650
Max Output per Channel Two Channels Driven
325
650
