Snake Doctor
I am making another attempt to clean up the wiring behind the scenes, one of the things I want to do is replace a 10 -12 foot network (Patch) cable that is going from one unit to another a distance of about 2-3 feet. My house is wired with Cat-5 does anyone one know if the Cat-6 is backward compatible?
A lot of the Cat-6 cables are flat, but I doubt if that matters. I could go with Cat-5, but I believe if you replace something it should be replaced with something better.
