Even after taking advantage of the UltraViolet disc-to-digital program and picking up a lot of back catalog titles along the way, I still have hundreds of movies on DVD. Some are not available via streaming. Some are not worth upgrading for various reasons (i.e. low budget classic kung fu movies look terrible in HD, because you can see all the wires). Some I want to either get the Blu-Ray or an HD streaming license for at some point. A few are out of print. Whatever the reason, I've still got hundreds of standard definition DVDs in my library.
Being unemployed afforded me a lot of time at my desk and I've been using that time to experiment with ripping both Blu-Rays and DVDs to my NAS. I was pleased to discover that creating a good H264 MKV DVD rip with no quality loss is no terribly difficult (Blu-Rays are much more complicated). First, I rip the disc using MakeMKV, which lets me dump the main movie, audio and subtitle files into an MKV container with no transcoding. Then, I run it through Handbrake to convert it to H264. The goal of this exercise is to create a file that is compatible with most devices, not to save space. While it is possible to compress a standard definition movie down to less than a gigabyte, my rips generally run over 3GB. Quality is the priority. These are the settings I use:
Container: MKV
Profile: High Profile
Constant Quality: 16
X264 Preset: Slow (Takes more time, but produces a smaller file without quality loss)
X264 Tune: Film (Unless it is hand-drawn animation)
Audio: Two tracks. One is AC3 or DTS pass-thru and the other is 256kbps AAC Stereo
Subtitles: I generally include the English subs. If there are forced subs, I burn them in.
Everything else is default values.
I use similar settings for Blu-Rays, but set the quality to somewhere between 18 and 21, depending on the movie. I try to keep the average bit-rate to somewhere around 12mbps. I should also note that I only compress the Blu-Rays that I also want to make available outside of my house. I will soon have full 1:1 rips of all of my Blu-Rays for local playback with full lossless audio.
Container: MKV
