Ok, I don't get it. Serious amplifier question
Maximo
I am in the hunt for an IB sub amp. I have seen several that are rated in stereo for both 4 ohms and 8ohms. But when bridged they are only rated at 8 ohms.
Why?
When bridged the power is doubled. If run to a 4 ohm load the current draw would also be doubled and apparently those amps can't handle outputting that much current.
When bridged mono, the load presented to the output circuit for each channel is halfed. So, if you have an 8 Ohm speaker wired to a single channel, the load on the amp is 8 ohms. If you take that same speaker and connect it to a bridged amp, the load to each channel of the amp is 4 ohms. So, if you put a 4 ohm speaker on a bridged amp, each output section sees a 2 ohm load and you have problems.
It really is that simple in practice, though the physics is more complicated.
