So Chris, you had satisfactory performance and then it later started screwing up? That's the issue I had, and even an external, expensive antenna didn't fix things for me. I had to go back to Dish just to get the standard networks.
I'm still baffled at how an antenna can work, then begin degrading and stop working.
^ I imagine it's possible one of the last two if any of those reasons. I'm wondering if could've been heat related being up in the probably the hottest part of the attic. The Leaf was mildly warped when I took it out of service. It's not the wiring as I used the same lead only extended (with a barrel) for the further distance of the outside antenna.
No I didn't. In the past I haven't had good luck with in line amplifiers. The run is only 35-40' to our master bedroom just below. Maybe not even that long. And my situation right now is working well.Did you have an inline amplifier for the longer lead cable? I used one on my antenna and it made a significant difference since the amp sits at the antenna and eliminates all cable loss.
These are very high frequencies and very low voltage signals, so the length of the cable AND every single connection create losses which can be a problem. An antenna isn't like a cable distribution system which already has an amp in it to reach each room connection. One has to add the amp.
