goaliechris
Hi all,
I know this is probably a ground loop issue but not sure how to solve this particular one. I have a Samsung 8000 series plasma and it is creating a hum through the speakers. If I turn off my amp (Rotel RMB 1095) the hum goes away. I have tried other combinations - cable box, cables, preamp, etc., and the issue is between the amp and the TV. I have both plugged into a Belkin PureAV power center but whether I have the TV or the amp plugged directly into the wall it still occurs. Also the hum does not change in volume if I turn the preamp volume up.
Any ideas on how I can defeat this hum as it's driving me nuts?
Thanks!
Thanks!
