Deleted member 133
Guest
Question: How long would you expect an Onkyo PR-SC886 to hold its settings after it's been unplugged / without power?
After 24-48 hours mine now reverts back completely to its default settings. Nothing sticks. Seems strange that this is happening given that I've had other, older, components stored away for years and when powered-up they still have the same settings as when they were unplugged and stored.
Follow-up question: if this is not normal, but due to some aged component, is it a user-serviceable fix?
This would not be normally an issue as it's plugged into a UPS, but I'm having problems with the contacts in a power receptacle for my main HT and occasionally the whole thing powers down. If I wigglel the plug contact is re-established. Until the leg heals I'm not going to be able to crawl around to fix it, and because I'm sometimes not down in the HT for a few days on end, I might not catch the power down before the settings get lost, which happened the other day.
