As a preface, I understand two things: First, this is likely subjective and personal preference. Second, speaker manufacturers almost always indicate in their owner's manuals how they'd like you to setup their speakers and/or how they were designed to be setup.
That said, is there some gauge, some reference, some way to determine where the listening position should ultimately be?
The two most common rules of thumb are the form an equilateral triangle rule and the 1.5X the distance rule. Assuming you hear a clear difference in sound between the two, how do you know which is right? Or is this simply a matter of preference and there is no "right" sound?
At Batman's GTG, Pauly and I experimented. He preferred - those speakers in that room - further apart and with some toe-in. In that instance, he was actually closer to the speakers than the speakers were from each other. I, on the other hand, preferred the sound with the speakers closer together and no toe-in. I remember him commenting "all I hear is midrange".
When Batman was here last weekend, we had a similar experiment. I put two pieces of tape of the floor. The first indicated the equidistance, the second indicated 1.5x the distance. Batman preferred the closer position and I preferred the further. Interestingly though, on one particular recording, I actually preferred an even closer position (Pauly would be proud). So now the brings each recording into the mix and hence my query.
Sure, if it sounds good to you, that's what matters. But I really think there's a "but this is how it's supposed to sound" out there. Is there?
