Why is it the most bone-headed simple projects can end up ruining an entire weekend?!? :angry-banghead: :angry-banghead:
I've got this glass shelf for my Center speaker. Its exactly the same width as my speaker, but the front sticks out 5" past the front of the speaker, and I'm trying to remove it to take the shelf to my local glass emporium to slice off 5", round the corners, and polish.
Two allen bolts go up thru the bottom of this bracket, thru the glass, and then thread into the round silver caps you see here. At first I thought the caps would pop off, revealing some kind of thin nut underneath, but I couldn't get them loose. I tried loosening the bolts from below, but the whole silver cap rotates along with it. I grabbed the edges of the cap with a newfangled Craftsman wrench with plastic-covered jaws, but couldn't hold it tight enough. Finally, I clamped on a set of ViseGrips (I knew they'd mar up the chrome but they're hidden anyway). I applied as much force as I dared (remember, its an Allen head) and for the life of me I can't break either one loose.
Does this setup look familiar to anyone? Is there some kind of trick to get these damn things loose? I would think it would be designed to loosen, as a wide glass shelf like that may need to be replaced due to breakage.
I also tried to remove the entire bracket from the wall and just leave it attached to the shelf, but as I suspected there's some kind of nut behind the wall that began spinning with the bolt just as soon as it was loose (fortunately it "grabbed" when I tightened it back in).
Any suggestions? :think:
