Russian Swat Sniper
Here's one of my faves from this guy. Get past the rifle opening to the Glock.
[youtube]http://www.youtube.com/watch?v=FbsgHbXubGU[/youtube]
DIYer said:
^ So he modified the pistol to go automatic?
Any gas operated firearm can be modified to operate in full automatic mode by filing the trigger sear, or fabricating an extractible metal plate that covers the sear.
Don't get caught with such modificatios unless you possess a class three firearms license.
I dont know how he cools that glock I would think it woult get so hot and warp the barrel.
Using a Glock like that basically destroys it. At this point, it's just a toy. Unless you are faced with a crowd of 1000 zombies. Then it becomes an essential tool.
Handgun barrels don't have the rifling count, nor the length to warp. The more likely scenario would be coppering or leading, depending on the bullet jacket, of the barrel riflings, which would impede accuracy. However, in this case, I highly doubt accuracy is a concern. (Old saying: if there's no lead in the air, there ain't no danger) :happy-smileygiantred:
Rifles, or long barreled weapons are a different story. The more rotations (twists/riflings) per inch, the more accurate the rifle. Although there is a down side, the more riflings, or twists in the barrel, more heat is generatedand barrel life suffers.
I own a heavy barreled . 220 Swift with a 1 in 8 twist (24" barrel), meaning for every eight inches of barrel the bullet travels it will rotate 360 degrees, or a full rotation. Barrel length is also a consideration when it comes to accuracy. Many weapons the military use (M-16) have 16" barrels for weight and maneuverability considerations. Their long range accuracy (1-14 twists) is between 200 and 300 yards.
