So I just got in the new Vifa tweeters for my line array, there is just one small problem. The old tweeters have a smaller hole, and there is no longer any material in the center for a hole saw to work (or circle jig).
Any idea how to get a larger hole while there is already an existing hole? I suppose I could use a jigsaw, but that would not be very clean, same with the router with the spiral bit.
Basically also the same issue with flush mounting the tweeter, since I always use a circle jig to start the outter diameter of the cut.
I'm sure someone here has some clever trick.
