Ok I could be wrong........
Now rammisframmis can tell me why what I said was totally wrong.
OK you're wrong. :laughing-lettersrofl:
Actually, you have it right. The rule of thumb about modern impedances is that the receiving end impedance should be 10 times or more the source impedance - something which is almost always the case with modern solid state gear (but something I have to pay attention to with my tube gear, which can have output impedances in the 50k Ohm region depending on the particular circuit).
If the receiving impedance does not meet this criteria, then the output from the sending device looses headroom, and will go into clipping earlier, or MUCH earlier if the load is too severe. Splitting the output from a modern preamp in two will almost surely not cause this problem, but if it gets more than that, it could be.
Preamps are ***mostly*** voltage sources, but this only true down to about 2k Ohms load, at which point they can start to act like current sources (obviously this point can be different depending on the "stiffness" of the output stage of the preamp). Power amps have a much lower point where they stop acting like voltage sources, and usually current protection kicks in before that point is reached.
Just NEVER use a "Y" adapater to sum together two OUTPUTS, no matter what component they're from. This is a recipe for at the least significant distortion, and smoke at the most extreme. You can sum two outputs if you use buildout resistors in each leg, at which point the currents sum (not the voltages technically), but this gets into DIY territory, and probably more than most people want to screw with.
