Need a small surge protector for my recently ordered subwoofer along with the Outlaw OWA4 receiver since it will be away from the main area.
Looking at the Tripp lite 2 outlet power strip or even the direct plugin one. Thoughts or suggestions?
Yes I have a regular outlet. But don't I want to be concerned about the two items getting fried?Why do you need a surge protector? Can't you just plug the subwoofer into your regular outlet?
Those are exactly the ones I was looking at. For $12.99 a month I'll let Amazon deliver. That drive may be a little much relative to convenience of deliveryAmazon, or if near you, Altex Electronics.
https://www.amazon.com/Tripp-Lite-P...d=1517936749&sr=8-6&keywords=TrippLite+IsoBar
https://www.amazon.com/Tripp-Lite-Protector-Right-Angle-INSURANCE/dp/B0000510R4/ref=sr_1_6?ie=UTF8&qid=1517936749&sr=8-6&keywords=TrippLite+IsoBar&th=1
and in Black!
https://www.amazon.com/Tripp-Lite-Protector-Right-Angle-INSURANCE/dp/B00006B81D/ref=sr_1_6?ie=UTF8&qid=1517936749&sr=8-6&keywords=TrippLite+IsoBar&th=1
Altex locations - the one in Houston doesn't appear far.
https://www.altex.com/locations.aspx
There is actually little chance of "frying" anything with typical voltage surges, and if you're afraid of things like direct lightning strikes, a puny power strip surge protector isn't going to do much except add to the ashes. To protect against lightening, you need more industrial strength protection, and even then lightning is not going to be stopped all the time. Almost all electronic devices these days have switching power supplies anyway (not to mention they usually have their own surge-absorbing device), and they can withstand over 260VAC since they need to operate at that voltage limit in European countries. So even if your line voltage were to more than double, the output of the power supply would be the same normal voltage.Yes I have a regular outlet. But don't I want to be concerned about the two items getting fried?
