This is part of the reason why tweeters often fail when amplifiers are underpowered for the signals they are being asked to drive. A loud bass signal can cause the treble to clip while not actually consuming all the power for itself.
Simply by removing the bass from the signal before it reaches the amplifer will reduce this potential issue pretty easily. Back when turntables were the norm, nearly all receivers and integrated amplifiers had subsonic filters that would filter out everything below 20Hz, or so, in order to reduce this potential problem. It was common for turntables to have LOTS of information below 20Hz that would cause the amplifier to put out energy at frequencies the speakers could reproduce anyway. Since the amps were driving that deep bass, they were more likely to clip the higher frequencies which distorted the desired musical information and could potentially damage the speakers.
In a HT, filtering the bass out of any speaker that cannot reproduce it will reduce the potential for this issue arising. Hence my general recommendation to set all speakers to small and adjust the crossover on the receiver at or slightly above the limits of the speakers. This not only ensures that the bass in the signal that cannot be reproduced by the speakers is sent to the subwoofer so that you will hear it, it also protects the speakers and can reduce the likelihood of clipping distortion in the midrange and treble.
In case you have never heard clipping, I have created 5 music files you can download and listen to.
Right click on the link below and SAVE the file, do not open it from the browser. Download it to your hard drive, scan it for viruses and then extract the MP3s in the file. Once extracted you will have five mp3 files -
http://www.soundenvironments.org/Data_Files/clipped.zip
First, listen to the file named "unclipped.mp3" to hear the original recording, unclipped.
Then, I suggest you listen to "clipped3dB.mp3". As an analogy, imagine a 100watt amp playing the unclipped file at the absolute maximum loudness without any clipping. Then, imagine the loudness remains the same, but the 100watt amp is replaced with a 50 watt amp. The clipped3dB file is what the music would sound like.
Next, play the "clipped6dB.mp3" file. This is like moving from the 100watt amp to a 25watt amp while keeping the loudness the same.
Then play the "clipped10dB.mp3" file. This is similar to moving from a 100watt amp to a 10watt amp.
Finally, play the "clipped20dB.mp3" file. This is an extreme example of moving from a 100watt amp to a 1watt amp.
Keep in mind, I am modelling the nature of transitor amplifiers to clip when the signal exceeds their voltage capabilities. Amps with soft clipping circuits and tube amplifiers do not react in this way.
