Beyerdynamic T1
Well clearly then it's just because you're using Apple equipment. :obscene-buttred:
I have a little portable CD player with coax digital output, I'll give it a try.
Don't ba a hater, lol. I actually really like the iPod touch as the user interface is easy enough and comparability is good. What would you consider a better option?
For portable players, don't know. Would need to have one that can do lossless digital output. I was thinking about trying an iBasso at one point (with IEMs when commuting), but I don't know if they have digital outputs.
walls said:
My only real complaint as well is long term comfort. Overall do you think they are worth the price tag though?
Yes. Don't know if they'd be worth the original ~$1200 manufacturer's price or whatever it was originally, but now that you can get them for $700 or less, I'd say they're quite worth it. I'll be keeping them.
Yeah me too, really want to hear your impressions of the HD800's. Have a feeling you may feel the same as I do about them.
Ok, well I think I'm ready to do some tests with the HD800 and bifrost, when you're ready to send them out.
walls said:
I use apple lossless for my iPod and while they claim it's identical to the CD it's recorded from I still get much improved sound quality when I go right from my CD players optical out to the Bifrost then the amp.
And I don't believe that the Ipure is degrading the sound at all since all I am using it for is a way to pass the digital signal to my Bifrost.
Are you sure the files are being copied to your iPod in lossless? I think the default setting in iTunes is to down-convert when copying...
Ok, it does, this is the one I was considering:
:text-link:
LL
