mcad64
Just curious, anyone use these things?? It would save the hassle of running a sub cable. I have a few questions. It operates on 2.4 GHz transmitter which I assume would not play nice with my Panasonic cordless phone. Dayton says there is a 25 ms latency. Would that be noticeable or could that somehow be compensated for by Audyssey. Lastly, SVS website says it has a frequency response of 6 Hz-23 kHz (- 3 dB points). Dayton Audio says it has a Frequency response: 15 to 20,000 Hz +1/-3 dB. So if you have a sub capable of going lower then 15 Hz this thing will not be able to deliver the goods? Is that correct?
Thanks,
Mike
Thanks,
Mike
