Harmony One vs. XBOX 360
Can anyone confirm that the Harmony One can control an Xbox360?
The logitech sight says it is compatible but I don't understand how that is since the Xbox doesn't have an IR sensor.
Huey
The Xbox 360 does have an ir sensor and the harmony one works fine with it.
Rob
I assumed it didn't because it's a game console and the controllers are RF. Since your post I looked at an on-line picture and the sensor is clearly visible.
What about the new Xbox 360 S... I can't see a sensor. Is there one there?
**** EDIT ****
Never mind... I found a couple of on-line sources that confirmed that there is indeed an IR sensor on the 360 S.
Thanks again.
