Deleted member 133
Guest
A Forum search turned up but a few mentions of HDtracks so I thought I'd start this one given my experience with it today.
It started with my noticing an ad for HDtracks in the latest edition of S&V, and a "special offer" to download a compilation album of 96/24 tracks for $5.98. So I bit.
Downloading was fairly easy - aided by the ability to use PayPal. I ended up with a folder containing the nine FLAC tracks, and a pdf of the liner notes (and a very low-res JPEG of the "cover").
But let me back up a bit.
I'm a huge purchaser of new and used discs: CDs, SACDs, DVD-A, DVD-V, BD. I "download" practically nothing - for a lot of reasons: I like albums as opposed to songs; I prefer to buy "high quality"; I then rip that to MP3 format for portable use. And I like using actual "discs." (Bonus: the cost of discs is pretty darn low if you shop around.)
So HDtracks had an initial appeal on two fronts: high-res downloads and entire albums. It would be a winner if I could easily take what I download and convert / burn it to disc. In other words, for me the download experience should ultimately result in the same end product as had I purchased the original disc.
So I gave it a shot.
With my FLAC-based "album" downloaded I then set off to burn it to CD.
First task was to take the FLAC files and convert them to WAV files. (For two reasons: I assume that a WAV CD, not FLAC, would be universally-playable, and besides that my version of NERO does not recognize FLAC. I also found WMP to be frustratingly useless - but maybe that's just me.) I used FreeRIP to convert the 96/24 files to WAV - noticing that while I could apparently preserve the 96kHz property, I was limited to 16bit with FreeRIP. Oh well; I was in experimentation mode. Conversion went smoothly - with track names and other data apparently preserved. (more on that later.)
At this point I got a bit sidetracked. I looked for an application that would preserve the full 96/24 through the FLAC to WAV conversion. A trial version of xrecode II did the trick - again preserving the track info.
Using NERO I now burned the 96/16 files to a CD. Nero "accepted" the format, and near as I can tell that's what it ended up burning. I can't really tell because during the burn process none of the track info was preserved. I can't find a way to determine if the tracks are what I think they are; I'm assuming they are.
I played that disc in a variety of CD, DVD and BD players - all without problem. The tracks all sound great. But through none of the devices (players, receivers, pre/pro) could I see any confirmation that they were 96/16.
But as I said all of the track metadata (if that's the proper term) seemed to be lost. All I had was "Track 1" etc and the playing time(s). And to me that's a deal-breaker.
I also set out to see if I could take those 96/24 WAV files and make a useable disc out of them. CD is out, but from some searching online apparently there are ways of using them by creating a DVD-A. However I could find no way to pull it off with either the software or blank discs that I had at my disposal. (Just burning them onto a regular blank DVD doesn't work.)
All of this took up a few hours of my time. In the end I was left somewhat disappointed. What would have helped would have been clear and simple instructions on HDtracks' site that would have allowed me to easily make what would have been the equivalent of a store-bought CD from the download. Afterall, other than for this "special offer" most full albums will set you back a ridiculously high amount of money using HDtracks - more than buying the equivalent disc online.
They try to make the sale on the basis of the 96/24 quality of their downloads, BUT as I found out, that's of no real use in creating a CD. I guess if someone wants all of their music to be computer / server-based, and can "feed" it to their system, then, at least technologically, it would work. Price-wise? Don't think so.
Anyhow, if anyone else has experience with HDtracks and wants to share, have at it.
