I decided to do a little rearranging today to better accommodate the new surrounds. I moved the seating back about 3-4 feet and then did the same with the mains and subs. Once everything was in its new location, I calibrated all the speakers and then threw in a multichannel disc to test things out. All seemed well. I then threw in your standard stereo CD and immediately noticed two things: 1) vocals were no longer "coming out of the fireplace" but rather distinctly from each of the mains and 2) the left main was noticeably louder.
During calibration, a +2.0 trim level setting for each of the mains yields exactly 75dB on my meter. Further, the test tone even seemed like it was playing at the same volume from each speaker to my ears. I played another disc and got the same result. Vocals aren't anchored to the center and the left speaker seems louder.
I switched inputs but got the same result.
I switched sources and got the same result.
I unplugged every power cable for over a minute and then tried again and got the same result.
I double, triple and quadruple checked all speaker cables. Everything is properly connected and nothing is out of phase.
All drivers and all tweeters are working properly.
I experimented with different seating locations. I experimented with different speaker locations. I put everything back where it was before I started. I emptied the fucking room and started over from scratch. I've been at this is 12:30 this afternoon. No matter what I do or what I try I get the same result. No soundstage and no imaging.
Can anyone help me?
Can anyone help me?
