Well, this is kind of a source component and DAC and not just a headphone amp per se... but it seems to fit in better in this section since it's used for headphones so here goes:
Just scored a brand new iBasso DX90 on head-fi for $300; on amazon they go for $380. I've been thinking about getting one of these for a while now.
For years I've been using a Sansa Clip 8GB - that I bought from GreatDane, actually. While it's SQ is adequate, there is a noticeable hiss if you're in a quiet room with decent IEMs (I currently use a vSonic GR07 which I'm very happy with). Plus it's fixed at 8GB, no expansion capability. Battery life isn't great, only about 4 hrs. Lastly, it has an annoying "feature" of putting a small gap of silence between tracks, which for pop/rock isn't a big deal, but many classical works flow continuously from one track to the next, so the interruption is noticeable. A bit of a pet peeve with me.
Been looking at iBasso for some time, because both models - DX50 and DX90 - have a microSD slot for extra storage. Plus an optical output if I want to connect it to other components (receiver or desktop headphone amp). They seem to be relatively well regarded as players. I probably would've been perfectly happy with the DX50, but the DX90 has a high end dual-mono DAC, actually based on the same sabre 32 DAC chip in the desktop DAC - Yulong DA8 - that I use with my full-size headphone rig. Probably not a huge deal since I generally will use this when commuting on metro/train anyway, a noisy environment, but hey... for ~$100 extra (what I paid vs new DX50), why not? At least then I won't worry about whether I'm sacrificing SQ. (and no this is one case where I'm not going to buy both of them and compare them myself. :snooty: )
Should arrive sometime next week, will post impressions.
:text-link:
:text-link:
