CMonster
Anyone know how to do a hard-reset on new Integra models (xx.4)? I bought a 20.4 to use in the rec area of our basement and it's forcing me to go through Audyssey setup before I can do anything else. Unfortunately, at the end of this process it says to unplug the setup mic. I do as I'm told and nothing; it just hangs on that screen apparently unable to detect that the mic has been unplugged. Very, very frustrating. I'm hoping a hard-reset will fix the issue but can't figure out how to do it. For the xx.3 models, I found this:
The xx.4 models don't have a [VCR/DVR] button. I tried the above procedure using each input button but no luck...
Thanks,
To reset the AV receiver or PrePro to its factory defaults, turn it on and, while holding down the [VCR/DVR] button, press the [ON/STANDBY] button. "Clear" will appear on the display and the AV receiver will enter Standby mode.
Thanks,
