okay so a few months ago I bought a 65" Samsung UHD 4K set.  I've really enjoyed the "up conversion" to simulated 4K on 1080p material like Bluray and Vudu HDX material.  I've applied HDR Plus to this material as I have no media that takes advantage of true HDR like the new UHD bluray players.  With HDR Plus added it made the colors on my screen come alive.
Now today I happened to receive a special hard drive that Samsung made that has 10 UHD movies and has 30 4K documentaries to really showcase the power of your TV. Now first off none of these movies or documentaries has HDR content so I kept my HDR Plus engaged so that the TV could apply HDR processing to the UHD content. I started off watching a couple 4K documentaries and yes it is jaw dropping. Then I watched "Life of Pi" in UHD then compared it to Vudu HDX version in 1080p and I gotta tell you yes the UHD did seem sharper up close but when sitting back 10 feet the difference was hardly noticeable. Yes there was a slight "sharpness" to the UHD compare to the HDX version but not so much of a difference that I don't think you'd notice in a blind A/B test.
Granted I got the hard drive at a fantastic price of 30.00 off of Amazon when two years ago the retail price was 399.00 but for 10 UHD movies and 30 or so 4K documentaries for 30.00 it was worth it. Now granted this hard drive only works on Samsung UHD TV's and it says the audio is is Dolby Digital Plus but since my preamp doesn't have 4K pass thru I had to use an optical cable out to my preamp so the best I'm gonna get is DD 5.1 then have the preamp upgrade the sound to DD EX 7.1
I figure if money is tight you might find buying a well made cheaper 1080p set will do you fine for many years to come as not many people are gonna spend the money on a UHD player than spend 30.00 per UHD movie just to get a slight improvement over 1080p granted I liked what HDR can do way better than what resolution can do as from 10 feet back your really not going to notice a big change unless you get a set bigger than 65"
UHD resolution is very nice when sitting three feet away though. 10 feet back and your not really gonna notice.
