I've got just a simple light in the middle of the ceiling of my HT/living room. It's on a dimmer switch. I was an early adopter of the Edison-base fluorescent bulbs, but quickly learned that they don't work with dimmer switches.
Since then, I'd read about newer fluorescents which can work with dimmer switches. Another incandescent burned out today, so I went to Home Despot and picked up a couple fluor's that can be used with dimmers (wow, the price has come down since the last time I bought).
Unfortunately, they buzz (the lights themselves, not my system) whenever I use the dimmer. Not as bad as the early bulbs, but still enough to where I wouldn't use them dimmed during a movie (I don't care for a completely dark room while watching movies).
I know a lot of you with dedicated theaters have sconces on the side wall; are they dimmable and what kind of light is in them? Do they make dimmable LCDs? (I'm pretty sure LCDs will eventually replace the fluorescents, which contain mercury).
I guess an oil lamp would work; what goes around, comes around! :happy-smileygiantred:
