Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Welcome to The Audio Annex! If you have any trouble logging in or signing up, please contact 'admin - at - theaudioannex.com'. Enjoy!
HTTPS (secure web browser connection) has been enabled - just add "https://" to the start of the URL in your address bar, e.g. "https://theaudioannex.com/forum/"
Congratulations! If you're seeing this notice, it means you're connected to the new server. Go ahead and post as usual, enjoy!
I've just upgraded the forum software to Xenforo 2.0. Please let me know if you have any problems with it. I'm still working on installing styles... coming soon.
Just a side project that's not going to be mass produced but won't share build information because many improvements could be made. I smell BULLSHIT!!!
True on the level of the horns reaching down to what we call bass but the look is true.
With the 4 inch driver in the horn it would be running 80 hz up to around 3 k and then the High driver would take the rest. I still wonder how well the sound will be out of the bottom horn on the 800 hz to 2 or 3k.
Add in a nice pair of digital amps for 20 or 30 watts to top and bottom. Adding a 3 way active crossover. Then one could do upto 100 hz for the sub, 100 hz up to 3 k for the mid and 3k up for the highs. The Sound Hound 3 way crossover would work very well on this application.
The only thing to look at is near field response and the sound field.
For the sub one would be fun to build an 8 inch or 10 inch version of the Corner horn.
If you like these mini speakers, do a search for Altec mini A7. They were promo units Altec sent to dealers back in the day. Very trick and hard to find now.
The problem is that a horn as small as those tiny La Scalas simply cannot produce hornloaded output below about 1kHz. While the speaker could produce lower frequencies, it won't be the high efficiency, hornloaded, sound or performance. To get to 80Hz would require a massively huge horn. Not even the infamous Voice of the Theater was horn loaded below 200Hz.
