PaulyT said:Huh, are those standard RCA terminals? That's an interesting way to use those, basically as soldering posts.
PaulyT said:Cool. From the pic, it seems like you're wiring to both the inside and outside of the jacks in some cases? That would give you the ability to wire on the underside of those boards, as well. That's just a cool idea, never seen that before. Do you design/tweak the underlying circuit diagrams, and the layout on these boards?
Everything you do is so very neat and tidy. Your pieces are almost as much of works of art as they are audio components. And I mean that in a good way, for sure.
heeman said:Very, VERY Nice WW.
What Capacitors are you using, the Yellow Ones?
Babs said:You are truly talented with your craft, WW! :eusa-clap: :text-coolphotos: :eusa-clap:
You should share more of your work!
If you're done hitting on my wife... :angry-cussingblack: :teasing-tease:Wardsweb said:I seem to remember Zing posting a headshot of you but I can't find it. You're a beautiful woman. Zing is a very lucky man.
