Yes, we are saying the same thing. I should have just said "the water flow is the current." Right, putting it in writing is the hard part; it all makes sense in my head, but that doesn't mean others will get what I'm saying.
Ok, I often have tried to explain to my buddies that have inquired before making purchases and I am simple folk so I explain it in terms that I can relate to.
I explain it as water flowing through a fire hose. The pressure in the hose is equivalent to voltage (even most fire fighters think pressure is most important, but they are wrong) more to follow. The flow measured in gallons per minute (gpm) in the hose is equivalent to current. And the friction loss in the hose is similar to impedance.
Pressure is important so the fire stream can reach the seat of the fire, but GPM is what puts out the fire (you have to put enough GPM on the fire to overcome the BTU's of heat energy being produced). Friction loss is the loss of potential energy when moving the water through the hose.
So, kinda sorta:
Voltage= Pressure
Current= Flow or GPM
Impedance= Friction Loss
And, Pauly's explanation about trying to keep the water tank full visits water supply, which is similar to the recent "what do you feed your system" thread. ATI used to make an amp that required a dedicated 30 amp circuit.
But, I really prefer the even simpler approach and now look at it like this. Dude from Parasound said wight is good so, at nearly 75 lbs, my ATI 1505 is good. :handgestures-thumbup: :handgestures-thumbup: :handgestures-thumbup:
