Old RCA Cable Colour Code
Lone Stranger
I did a Google search for my quest but found nothing. My housemate has an old Garrard turntable that I am hooking up to my Yamaha stereo receiver. The RCA cables are grey and brown. Does anybody know what cable is left or right? No reds or whites on that particular turntable.
Botch
Wow, never heard of grey/brown. Do you listen to classical? If so, the violins should be on the left and the basses on the right. For pop music, it probably doesn't matter (or you could confirm proper orientation with headphones...)
Try this LINKY
Yesfan70
I'm famous now bitches! vvvvv
If they are like any other RCA cable, colors won't matter. The trick is not to cross-wire them (L to R or R to L).
Lone Stranger
The cables are hard-wired into the turntable so in this case it would make a difference. I'll have to look through mine and my house mate's LP collection to see if there is a good reference recording to sound test it with.
Yesfan70
Hard wired? Ooo I didn't think about that. Assuming it's not labeled on the TT, I'm willing to bet when you're looking at the back of the TT, the cables would be designated "left to right", so which ever color is on the the left side would be the cable for the left channel. Same thing for the right cable.
Lone Stranger
OK thanks guys for your input. I ended up opening up the bottom of the turntable and traced the connection to the stylus wires. The grey cable is left, brown is right.
