Just an update for my 2.1 to 5.1 update.
I had an issue with how to mount my rears for my 5.1 update. I decided to purchase the Pinpoint AM-40 Wall mounts, but needed to find a way to these mounts from the ceiling. First of all I screwed up and ordered 2 sets of mounts, because the ad was not clear that each box has mounts for 2 speakers.
I took some 1/8" CRS Plate and drilled a hole in the center to fit the tubing for the hanger. I also drilled 4 mounting holes and countersank them.
I also took some 1/8 CRS Plate and copied the mount from the AM-40 Mounts and drill 4 new mounting holes.
After having a friend weld the top mounts and the mounts for the AM-40's to the 1/2" tube, I primed and painted with a black satin paint.
A couple of views of the finished product.
