bmwuk said:Does the Harmony 650 have learning as well? Reposition soft buttons?
bmwuk said:http://www.bestbuy.com/site/logitec...mote/9365402.p?id=1218092151754&skuId=9365402
How does this compare to the 650? Thanks.
Here's one site: http://www.iconharmony.com/icons/home There are many others, just type "Logitech Harmony 650 icons" into Google. I don't know if they have city-specific icons; instead of "KUTV" I just use "CBS" and that's fine (the site I've used did have icons for all the different ESPN channels).bmwuk said:Where can I find a bunch of icons to use for favorite channels? I am in Houston, utilizing AT&T U-verse. Some seem dated and I can't find items like Disney Jr or local icons. Thanks.
CMonster said:Be prepared to tweak for the next week or so. I find that the Harmony software gets you about 80% or so there just by entering your devices and setting up the activities but as you use it you'll find issues that need to be corrected or adjustments based on preferences.
You shouldn't have had to teach the Harmony anything from your TV remote - if you're exact Samsung isn't in the database just pick a different model and I bet it'll work.
bmwuk said:Also, it seems the smart hub button is excluded from the TV remote. How do I access it or do I need to teach the Harmony? Thanks.
