TKoP
Just one of those things, thinking of what I might look to buy if I were to try and build an relatively inexpensive powered speaker system for my bedroom.
Since I wanted to avoid work as much as possible, i jumped on Madisound's website to look at some full range speakers that I thought might have the response I was looking for and were also relatively inexpensive.
The one I cam across that looked like it might fit the bill was the Aurasound NS3-193-4A1 3" Full Range driver. Looks like it has an f3 of ~85hz, which is way better than I would have expected, a pretty flat response graph as well. And it was on sale at $13.50/driver.
For power, i found a 40w (2x20w) mini class D plate amp on Parts Express that also had Bluetooth. This was going to cost more at $36 for the unit, but better than other options i saw there.
The recommended (sealed) box size was kind of vague at 2-3 liters (which should be 122in^3 to 183 in^3), but in either case, would be small enough to fit on my night stand. The idea is to connect it to my Echo Dot that is already in there.
Anybody have any thoughts? I'm not sure what T/S parameters might be ideal for a project such as this, so the drivers picked could be total crap for all I know.
