nelmr
When calibrating using the Receiver, I end up being about 3-5 db lower in volume setting then when I use the S&V disk. The mains are 3dB lower, whereas the surrounds are 5dB lower.
The test tone seems higher pitched on the S&V disk compared to the Receiver's test tones. Any ideas for the discrepancy? I had the same issue with my previous receiver, which had test tones sounding like the new receiver. Which is more accurate to use? I don't even watch movies on my DVD player anymore, everything is now BD on my PS3.
My big concerns are:
1) Why do all speakers match SPL when using the receiver tones, whereas with the S&V disk the right front is -1dB lower and the rears 2dB lower compared to the other speakers.
2) I'm trying to calibrate for reference level. With the receiver (DENON 3310), I assume one should set for 0dB and the adjust the trims as it's a relative scale unlike my Yamaha. However, If I use the S&V disk, I need to use different trim settings to keep the 0dB reference mark. So this is in essence why I ask which is more accurate.
