Towen7 said:Why 6 instead of 7 channels if you're suggesting multiple speakers for each rear surround channel?
What am I missing here? The purpose of calibration is to achieve the same SPL at the listening position from all speakers. So what if one speaker is just a few inches away and others are several feet away?Flint said:How can you hear the other of the channel if the speaker playing it is 4dB to 6dB SPL softer due to being farther away.
Flint said:Same thing as having two speakers playing stereo under the eaves of the porch and sitting directly underneath one of them.
Zing said:What am I missing here? The purpose of calibration is to achieve the same SPL at the listening position from all speakers. So what if one speaker is just a few inches away and others are several feet away?Flint said:How can you hear the other of the channel if the speaker playing it is 4dB to 6dB SPL softer due to being farther away.
You've mentioned the importance of tuning it well more than once. I assumed by 'tune' you were referring to calibration.
Have I missed something?
Flint said:Okay... so I have been speaking to some of my brilliant theater audio engineers about your situation (gave me a reason to call and catch up with old friends) and they came to the same conclusion, which I thought was brilliant.
They suggested you do a 6.1 signal setup (side surrounds and mono rear surround) and place three to four speakers on the floor behind the couch (assuming you can pull the couch out the requisite inches to allow for them). They said to put an EQ on the rear floor speakers to make the general tone balanced with the others (cut the bass and boost the treble) and tune the setup well.
The side surrounds should be placed to the side aimed directly at the listeners about a foot to two feet above the heads of the seated listeners.
Huey said:I know nothing of these, so I don't know if it could be made to work, but what about using a soundbar, but only in reverse? I don't know how customizable a soundbar is, but it might be an easy and clean solution.
Botch said:Seek out four or five Pontiac Fieros in your local junkyards, pull these:
...and adapt them to an old track-lighting system, bolted behind the sofa. :geek:
Randy said:Huey said:I know nothing of these, so I don't know if it could be made to work, but what about using a soundbar, but only in reverse? I don't know how customizable a soundbar is, but it might be an easy and clean solution.
That may be a super simple solution to achieve Flint's recommendation, especially if he can find one that is closely timber matched to his others.
I think Flint's recommendation makes sense. It may be hard to pull off, but it should achieve the goals of an immersive and consistent soundfield.
Damn difficult rooms.
What do you drive now, a Miata? :violence-torch:Randy said:...I owned 2 Fieros.
Zing said:What do you drive now, a Miata? :violence-torch:Randy said:...I owned 2 Fieros.
