Rope said:Vinyl -
Your traps and treatments are just plain damn fine. Kudos to Vinyl and Super Chunks!
Word.
How does it sound?
Rope said:Vinyl -
I used to have lingering bass frequencies in the 75/80 Hz regions in the audio section which is in the opposite side of the room – the two absorbers flanking the monitor plus a much denser 2’x3’ on the floor behind the HT rack which you don’t see are specifically aimed at curbing these frequencies – all this plus the combined absorbers/diffusers on the front wall of the audio section has resolved this slight audiophool annoyance – also tucked away for audio only is a little 10” sub set at 40Hz augmenting the Maggie’s which play at full range this has also contributed to the final results – the overall sound is now clearer and more detailed – acoustic panels are winners and recommended.The opposite end of the room may help to comprehend the full scope of the space and treatment.milpool said:Rope said:Vinyl -
Word.
How does it sound?
You may need to read some articles on the subject – below is a simple quote from GIK plenty more articles available from all sellers of such.Towen7 said:I'm still curious about any benefir to treating wall/cieling corners that are 45 degrees.
Vinyl said:Edit: Have you built any absorbers as of yet?Towen7 said:I'm still curious about any benefir to treating wall/cieling corners that are 45 degrees.
Towen7 said:I'm not being clear. My ceiling/wall joints are not 90 degrees, they are 45s. Is there any benefit to treating 45 degree corners?
malsackj said:But Pauly has a wonderful pretty set of ladies that always keep him busy!
