lakedmb
Ok, so the more I look into the subs the more confused I become about the whole thing.
The deadline to purchase the Danley is in September, which means that I have a until then to make a decision about purchasing it. My budget for a sub is $2000 and less is definitely better. My room will be 4000 cu. ft. and sealed. Dimensions are 16x25x10.
After some research I am not sure what would be the best decision. I have two SVS 12" subs that I can use to build my own, which is always an option, though right now it is my least favorite option. I am hoping to use those subs to build two small sealed subs for two other locations in my house.
One idea that keeps bouncing around in my head is to create a similar setup to SoundHound with 18" subs, smaller room so less subs I would think. Space isn't a big concern since this room will be dedicated to just the theater. The low frequencies from his setup were much smoother and fuller than the pair of Danley's I heard two weeks ago.
I have read about building a sub that should perform comparatively with the Danley using 18" drivers, something like the Maelstrom and LTS design(?).
I have also thought about a pair of HSU's if I can find a pair used.
Another idea is a used SVS PB13 Ultra, not sure how the output compares to other options.
Some people have mentioned an IB design, but I don't believe it would work well in this situation. I have a room next to the theater room, but is only half the size and will be used as a workshop.
I'm sure that I will think of more ideas and questions along the way.
Thanks.
Thanks.
