Utah HS1B speaker rebuild
These were 2-way with a 12" woofer and two mid/tweeters. I will add a horn tweeter and a new 3-way crossover.
thats one day? dude, you really got to tamper it down man. we looking super bad at this point.
kidding aside that looks awesome.
A clear coat gives depth to any wood grain. A high gloss gives even more depth. When the wood already has great contrast, the gloss accentuates it.
Was that an iron-on veneer? You did that all in one day, and I knew that Macassar had great contrast, possibly even some gloss as a veneer due to its hardness, but the towel reflections were just too much.
One day, wow.
I use a rubber glue roller to apply titebond on the veneer and the speaker, let the glue dry, place the veneer on the speaker and use an iron to heat the veneer, that activates the glue bonding the two together.
Thanks; did you apply some kind of finish after that, the same day?
The sheets had a prefinish applied. This goes on heavy and typically orange peels bad. So, the process is to sand it down with some 150 grit to a smooth surface, some 220, some 400 and finish with some polishing with 3M Perfect-It. I took a short cut and sprayed a final coat after the 150. It isn't as good as the original process but is good enough for some low end 70's cabinets. It still gives a lot of depth to the finish. It is like putting on a dozen coats of lacquer.
here is the updated layout. I don't remember where I got the tweeters. I only remember they were cheap, like $20 or so for the pair. The horns are plastic. Something like a Peavy or Nippon.
I really appreciate your response. Did your upgrades make the Utahs sound a lot better? I’m guess YES!!!
