Wardsweb said:
DIYer said:
soundhound said:
Using the VOTT in small bedroom sized rooms (I've done it) doesn't yield the best of results either.
Will smaller horn like 811B (instead of 511B) be a better choice for smaller room?
The VOTT issue isn't the horn, actually the 511B with the 802-8g (tangerine phase plug) is sublime. The mid range is just liquid, open and airy. The problem is the bass. The cabinet was made for a long throw into a movie theater or large recording studio. Small rooms can not accomodate the approx 12-13 foot bass fold. So your bass is less and not as tight.
From my experience, the 811 would indeed be more suited to a very small room, however the VOTT was designed for screening room sized theaters. My A7-500s work well in my 30' long room, however I wouldn't have turned down a room which was 10 feet longer. The biggest issue I've found is that of a large enough space to allow the LF and HF horns to blend well; in a small room they are perceived as individual sound sources instead of an integrated blend.
The 902 was the Altec driver which used the "tangerine" phase plug (it also used a ferrite magnet), designed in the late 1970s while I worked at Altec Lansing as an engineer, while they were still the original company located in Anaheim CA. I bought two of the drivers the week they were released, hoping the promise of more extended high end would obsolete the 802s I had at the time.
WRONG! Those were the absolute worst sounding drivers I had ever heard compared to the 802s. Yeah, they had more high end, but they were harsh beyond belief. I sold them within a week at a loss to one of the technicians on the electronics assembly line. I found the same was true for all the drivers which used the "tangerine" phase plug. In my opinion it was a wrong move by Altec, which at the time was struggling financially (they finally left Anaheim for Oklahoma City right after I left the company in the early 1980s). Altec also used piezo tweeters in their home speaker line at the time (the guts of the driver was literally a "rat chaser" module which they bought from an OEM which was unrelated to the sound industry).
In the end, I believe the peak period for Altec designs was the mid 1970s; everything designed later than that I found to sound absolutely horrible. Perhaps they were grasping for straws with "new" designs in order to keep the company solvent. They also launched a car audio line during that period called "Voice of the Highway" which was actually pretty good. The radical for the time car power amplifier was designed by a buddy of mine at Altec (I designed all of the automated testing equipment to test that amplifier in the Tijuana, Mexico factory which assembled them).
At any rate, I strongly advise people to stick with the 802 which used the conventional radial phase plug and Alnico magnet (the 902 used a ferrite "mud" magnet), mated to one of the 811 or 511 exponential horns. However those horns absolutely need to have thick sound deadening material (Aquaplas was the material Altec and JBL used for this purpose) applied to the outside of the horn to damp some really nasty resonances those horns have in their original un-damped state.
