Spent some time this morning doing an initial audition of the A18 that arrived yesterday. I say initial, because I'll be doing at least a few more rounds of this in the near future. First, I'm using an RCA/unbalanced connection between the DAC and the amp. I've heard it said on Head-Fi that there's some (slight) sonic differences between that and the XLR/balanced inputs of the A18; my DAC does have XLR out, as does the DA8 that's coming, I just don't (yet) have the cables for it. I'll repeat this later with XLR, just to see if there's any truth to that.
Also, I'm using my beloved modded Denons still. I will repeat this yet again when I get the T1 next week. And then there will be different DACs... The problem with so much gear is that there are a gazillion different combinations of components, and I don't have the time or patience to evaluate every single combinatorial possibility.
I'm not going to go through a track-by-track commentary on this comparison. Mainly because I'd end up saying a lot of the same things over and over. Rather, I'll just provide general comparisons, with the occasional reference to particular tracks if need be. I'm using the track list I posted earlier:
:text-link:
Complete signal path for this round is: FLAC -> squeezebox -> optical/toslink -> M-Audio SuperDAC 2496 -> RCA/unbalanced -> WA6 or A18 -> Denon D5000
FYI the WA6 is $699 new, plus >$200 more for the tubes I've got. The A18 was $899 new, though it's been discontinued. I got both of these used, so I didn't pay that much, but I mention this mainly to indicate that the price range we're talking about is similar for the two.
So... maybe now you'd like to hear something about the sound...
:happy-smileygiantred:
Well, let me start by saying that the Yulong A18 is the best solid state amp I have personally owned and carefully evaluated. Y'all know I'm biased towards tubes, as I generally feel that solid state often has a dry, somewhat harsh and fatiguing sound compared to tubes. I got this A18 specifically because of claims (again on Head-Fi) that it has a "tube-like" sound. And... I agree. This is the first SS amp I've found that I can listen to for hours without experiencing fatigue. I could definitely use this amp for everyday listening.
So the big question... is it better than the WA6? Well, yes and no. There are some things I like a lot about it, and some things I like more on the WA6 still.
Strengths of the A18 in comparison: firstly, the bass is a little better controlled. Not that it's necessarily louder or lower, but tighter - maybe better damping, not sure what the right word is. And it's not an enormous difference, but I think it's there. Secondly, the sound across the entire frequency spectrum is more consistent when the music is very loud and full and covering a broad range of highs, mids, and lows. That is, sometimes with the WA6, there's a very slight "thickening" or echo or something in the midrange when, say, a full orchestra is playing all-out (like in the Stravinsky tracks). With the A18, I don't hear that. The response is smooth and natural across the whole spectrum even in these louder moments. And I don't mean just turning up the volume, although that maybe does a little of the same thing. I don't tend to listen at ear-splitting volumes. But if you've ever heard a live orchestra up close, it can be pretty damn loud, and I like to listen at "realistic" levels.
Strengths of the WA6: precision of imaging and soundstage. By this I mean the apparent breadth - and even depth - of the stereo "landscape" of sounds, and how precisely localized a given sound appears to be. The A18 is pretty good in this regard - noticeably better than the Meier I reviewed recently. But the WA6 still takes the cake here. It has a way of presenting a depth (front and back) when there's a lot going on in a recording, many instruments layered into the mix, like the Rodrigo y Gabriela track. Or the Bob James, where with the WA6 I get the sense that the horns are
behind the piano. While the left/right imaging is pretty good with the A18, I don't get that depth, at least not as much.
So overall, if I had to pick one or the other, I'm pretty sure I'd still go with the WA6, mainly because a good soundstage presentation is my #1 personal goal. I'm very curious to see if the XLR connection to the A18 makes any difference in this (though I'm skeptical), or, especially, whether going to the Beyer T1 headphones will change or reinforce this opinion.
FYI there's a tiny bit of hiss in the A18 when I turn the volume all the way up but nothing playing. It's very slight, and you need to be in a quiet room to hear it. Certainly not an issue when listening at normal levels; kind of like hiss from a speaker when you put your ear right up to it. In comparison, the WA6 has a tiny bit of a hum, but totally independent of the volume setting. I guess just a residual thing from the tubes. But again it's tiny, you can only hear it in a quiet room by pulling the headphone plug in and out of the jack. You'd never hear it under any music.
