Dentman
I've been wanting to upgrade my downstairs family room audio system for a while now. This room is also open to my kitchen. Currently we have a cheap,($89.00) Insignia bluetooth sound bar in place.
We very seldom sit in this room or watch TV, in fact the sound bar isn't even hooked up to the TV. I use it for both podcasts and music while cooking or cleaning, that's about it.
After some talks with Franklin about me wanting to upgrade the X-overs and drivers in my little Minimus 7's and pair them with a vintage Pioneer receiver I have laying around, he talked me out of it. He suggested he build me something. I told him about my very limited budget and he still managed to come up with what looks like a very good solution. He will be charging me a very reasonable fee for his services as well. Still this will come in at a great price for the complete project. Here's a copy of his latest email to concerning the design.
"Jack -
Attached is a drawing of the plans for the 2.1 speaker system we are working on.
The width of the sub module is 22 inches.
The width of the satellite speaker is 6.75 inches
The combines width when placed against one another is 35.5 inches
All enclosures are 5 inches height without feet. We will put the tallest feet which will fit into the cavity to get the most clearance for the sub's down-firing driver.
The amp in this design is mounted on the rear left of the subwoofer. We could easily flip it over and put it on the rear right, so look at where you are placing it and consider which side you'd prefer to put it on before we glue-up the enclosure.
The port for the sub is on the rear right in the drawing. (note that the two front to back blocks of wood inside the sub enclosure will be braces with lots of holes cut in them to let air pass through freely)
The satellites are simple sealed boxes, so nothing fancy there."
"Jack -
