Cosmetically absolutely. There's a minor scratch on the front but until I saw my own picture, I had not noted it. I have the amp recessed back in my little stand and due to space constraints, I shifted the stand to the right so the center could stay centered and I could move up the Oppo playerLooks like it's in pretty good condition.
Hooked up yes. Critical listening no.Have you had a chance to hook the ATI up to your system yet and have a listen?
Ha ha. I'm actually at Sicario Soldado right now. I believe I will finish this movie since I'm at the theater.^He'll do that but first he has to finish 4 movies, 2 concert videos and yesterday's lunch.
I know many reputable companies such as ATI among others have Class D amps. The size and not Needing the ventilation as much seems very appealing. What is lost vs using the class a/b setup? Just curiousI would think the largest benefit from the ATI is that you will be able to plug it into your system and be able to forget about it until you will it to your kids. Honestly, the technology of solid state power amplifiers hasn't changed substantially since the 1980s. The largest change now is toward class D, which is cheaper, lighter and more power efficient; and its "good enough" for the vast, vast majority of people.
Class D has two main limitations; one is a relatively lower damping factor due to the need to have an inductor in series with the output to filter high frequency clocking noise, and two, the presence of that residual clocking noise on the output of the amplifier in spite of the series inductor.I know many reputable companies such as ATI among others have Class D amps. The size and not Needing the ventilation as much seems very appealing. What is lost vs using the class a/b setup? Just curious
Thank youClass D has two main limitations; one is a relatively lower damping factor due to the need to have an inductor in series with the output to filter high frequency clocking noise, and two, the presence of that residual clocking noise on the output of the amplifier in spite of the series inductor.
With demanding speakers which have impedances which dip to as low as 1 ohm, the damping factor can be less than it would be with a class A/B amplifier. Its not really a problem with more normal easier to drive speakers though.
A larger issue in my opinion is the presence of residual clocking noise on the output of the amplifier which I normally see as 1 or 2 volts. This can cause unpredictable intermodulation distortions with the main audio signal which can be audible depending on the tweeter driver, your sensitivity to hearing this type of distortion, and the music you listen to. The digital amplifier manufacturers will swear that this is not a problem, obviously.
ATI does make tons of class D amplifiers; obviously they know the writing is on the wall and class A/B is ultimately a dead-end for mass manufacturing.
...I am completely convinced that the panels had a vastly more significant impact on what you hear than any properly functioning hifi amp could ever have on the sound.
I'm fully aware. I will do a/b on receiver and amp. Will be a while before doing tgough.I am glad you enjoy the amp.
But, purely for clarity on the issue, if you hadn't critically listened to the amp since also upgrading and adding acoustic panels I am completely convinced that the panels had a vastly more significant impact on what you hear than any properly functioning hifi amp could ever have on the sound.
Of course, a good amp is always nice to have, especially when you start playing content loud. At levels below the proverbial "Dolby reference level" any decent 75W minimum amp will do a fine job and replacing it won't make much of a difference, if any at all. However, if you really are pushing the SPLs and have some truly dynamic recordings which may overwhelm a lower end sub 100 W amp, a good larger amp is always a great thing.
