Welcome to The Audio Annex! If you have any trouble logging in or signing up, please contact 'admin - at - theaudioannex.com'. Enjoy!
HTTPS (secure web browser connection) has been enabled - just add "https://" to the start of the URL in your address bar, e.g. "https://theaudioannex.com/forum/"
Congratulations! If you're seeing this notice, it means you're connected to the new server. Go ahead and post as usual, enjoy!
I've just upgraded the forum software to Xenforo 2.0. Please let me know if you have any problems with it. I'm still working on installing styles... coming soon.
Been on the hunt for another pair of 650's for use at my office and finally took the plunge. J&R has them on sale with free shipping for $356, figured it was gonna be hard to beat that deal.
Now to see how well they stack up against my three year old 650's!! :banana-rock:
I don't know if it's a fact that they changed the sound sig but there was talk. It was too long ago to remember much about it. I did use my Aphex 204 to add lower treble overall.
I never read anything about a sound change, but I will be able to A/B the new ones with my almost five year old ones so I will let ya all know what I think after I get em!
Also a mod that I did was to remove the small foam behind the driver. There is foam in front of the driver also. It's worth experimenting with.
Here's a link that describes the foam mod. I did a variation on the foam in the front. I call it the nickel mod, because I used a nickel coin to create a hole in the foam but did not remove the entire piece like the link shows.
After just a quick A/B it seems as though Senn has indeed changed something.......but IMO for the better. They are still silky smooth with great bass but it seems as though the new 650's are a tad "faster" if that makes sense?
The overall sound is pretty much the same besides that, so I will give the new set some break in time and do a better review later this week.
I would love to hear them.. I've owned Senn's HD600 for a number of years and really love. When I heard the Senn HD 650 is was so familiar I couldn't really tell the difference.
BTW,
Rope,
The 595 are basically the HD600 for less with a bit less "finish" (I'm sure I didn't need to tell you that).
