What about me? :sad-teareye:soundhound said:Pauly & DIYer.... I took some new pictures...
Zing said:What about me? :sad-teareye:soundhound said:Pauly & DIYer.... I took some new pictures...
Thanks for the update s.h. I too have installed a supertweeter at the same location as yours. I use Beyma CP21/F which has similar spec as your JBL 2405H except the mounting holes are configured differently which I had to use a small wooden baffle to compensate. For those interested, I will start a thread in couple weeks with some images.soundhound said:Pauly & DIYer.... I took some new pictures of my room which pretty clearly show the supertweeters mounted on top of the Altec horns. Link below.
Do you use active crossover? If not, you know what to do now.Zing said:What about me? :sad-teareye:
DIYer said:Thanks for the update s.h. I too have installed a supertweeter at the same location as yours. I use Beyma CP21/F which has similar spec as your JBL 2405H except the mounting holes are configured differently which I had to use a small wooden baffle to compensate for it. For those interested, I will start a thread in couple weeks with some images.
DIYer said:Do you use active crossover? If not, you know what to do now.Zing said:What about me? :sad-teareye:![]()
I will post those when I start a thread. As for the crossover, it's passively high passed from Altec 802D (connected parallel) at 11KHz with 12db slope using cap and inductor. There is no passive x-over for 802D at this time (I have the parts for it and I am planning on trying it which is why I haven't started a thread). The current configuration picks up where 802D rolls off and gives a flat response to 20KHz.soundhound said:I'd be interested in some more details, crossover frequency, graphs, pics etc.
DIYer said:I will post those when I start a thread. As for the crossover, it's passively high passed from Altec 802D (connected parallel) at 11KHz with 12db slope using cap and inductor. There is no passive x-over for 802D at this time (I have the parts for it and I am planning on trying it which is why I haven't started a thread). The current configuration picks up where 802D rolls off and gives a flat response to 20KHz.soundhound said:I'd be interested in some more details, crossover frequency, graphs, pics etc.
DIYer said:I forgot to mention one component, there is L-pad installed for super tweeter which allows me to adjust the output of upper end frequency. I haven't found a need to adjust it after the initial calibration. I still need more listening time to judge my speaker mod. More to come soon but the initial reaction I've gotten was, "Hmmmm, interesting". :think:
PaulyT said:Cool, you mean those little alien eye-stalk looking things? Sweet. Now all you need is a laser light setup that responds to the music. And a fog machine. :teasing-neener:
soundhound said:DIYer said:Have you added couple of tube amps to your equipment list? I see Dynaco ST-70 and something else next to it.
It's not being used at the moment. In the space where the Ampex tape recorder was in those pictures, I now have a Canon 9500 MKII printer, and I moved the tape recorder next to the ST-70.
BTW Most of those pictures were taken with the Canon EF 15mm 2.8 fisheye lens, and run through a rectilinear converter plug-in in photoshop CS5 to remove most of the distortion. Photoshop CS5 also has a rectilinear converter but it adds distortion of its own on the edges of the frames. The photoshop converter works for some pictures, but the Imaging Trends converter works best in most instances, even though some things like the ceiling beams are still curved.
TitaniumTroy said:SH, I am curious why the addition of the supertweeters? Also I cannot seem to find the pics of the supertweets.
Nufan said:soundhound said:15mm 2.8 DROOL!!! What was that bad boy connected to?
I shoot with the Canon 40D right now, looking to get a 5D!
The DirtMerchant said:Maybe I'm just blind and dumb (and risking the vaunted SoundHound piss on my speaker wire)
but I don't see any HT pics in here: http://soundhoundimageworkz.smugmug.com/
Only: Portraiture/Architectural/Landscape/Disneyland/Macro
and I don't see any HT pics in those folders...
soundhound said:The DirtMerchant said:Maybe I'm just blind and dumb (and risking the vaunted SoundHound piss on my speaker wire)
That's cuz they ain't there. I took them down to make some new shots, and haven't gotten around to uploading the new ones. Benn kinda busy lately.
The DirtMerchant said:soundhound said:The DirtMerchant said:Maybe I'm just blind and dumb (and risking the vaunted SoundHound piss on my speaker wire)
Makes sense. At least I'm not dumb and blind.
