soundhound
The pictures are back up for those of you who asked...
Rope said:With that lens your room looks ginormous. Great pics, thanks for sharing them.
Vinyl said:Great room - lens not quite fisheye - must be close to 14mm?
PaulyT said:Are those the horn/supertweeter crossovers sitting "naked" on the VOTTS behind the horns?
Then shouldn't it be moved to TGIF section, Pauly?soundhound said:PaulyT said:Are those the horn/supertweeter crossovers sitting "naked" on the VOTTS behind the horns?
Yes.
DIYer said:What kind of equalizer are you using for the mains?
DIYer said:I thought you applied plaster over the back of curved portion to dampen the bass horn. :?:
soundhound said:Added a couple of tech geek shots of the back of my crossover / amplifier rack. The blue box with two knobs is the EQ filter for the HF horns (500Hz to 11kHz). The gray box on top of the ATI 1504 amp (4 channel for the surrounds) is a switch which routes signals to the surrounds either directly from the OPPO BDP-83 SE, from the delays and reverbs below the Dynaco MKIII tube amps for adding ambience to stereo recordings, or from the outputs of my ProTools digital audio workstation.
Above the SET tube amp is the active crossover, and above that, a Behringeer Feedback Destroyer Pro EQ for the subwoofers, a Furman power strip, active EQ for the woofers, and VU meters for monitoring levels.
The electronics directly above the ATI amplifier is a regulated DC 5 volt power supply for powering the filaments in the SET amplifier. This amp has to have squeaky clean power on the filaments otherwise buzz will be heard through the HF horns; at 106dB efficiency, any noise at all from the power amp will be heard.
Notice the chains to keep things in place in case of eqrthquakes. :scared-yipes:
Rope, he meant his quad-subs.Rope said:One of the many perks of living in So Cal.![]()
