CD Rack
It is a rather simple design.
I made the same design, however much smaller for a DVD Collection in the den. We have now out grown it.
The trick is to make the box (frame) about 0.5" deeper than the shelves. This will leave ample room for the finished face (I used Poplar, 1 x 2). The frame I made from 3/4" Birch Plywood and ripped it to 6 1/8". The shelves were made from 1 x 6" clear pine.
The first coat of paint is almost complete and I think it will take a min of 2 coats.
Will show finished pic's within a couple of weeks.
We're lookin' forward to it Heeman!
Thanks,
koufax65 said:
What kind of joinery did you use for this?
No joinery at all, everything is butted together. The frame was held with 1-3/4" Brads, glued and screwed with 1-5/8" screws. The shelves are glued and held with the 1-3/4" brads.
Looks fantastic!!!! I thought I was the only guy on the planet that still has 1000+ CD's. LOL!
Finally Done!
Pretty happy with the way that it came out................plenty of room to grow into.
Thanks Zing!
If I ever build another one of these (originally it was going to be twice the size to hold my CD's and DVD/BR overflow collection), I will paint all of the wood prior to assembly.
As one of the guys noted, it really is not a very hard project to do.
Very nice. And to buy something of that size would cost hundreds, no doubt.
Yep. I have one that holds about 1500 CDs. It's almost full (about two rows left), but I also have quite a few upstairs that I was ripping to my PC. Mine was about $300 and it was a cheapie from Racks & Stands.
Heeman,
If you made the shelves adjustable, then I would be tempted to put your DVD/BR collection in there too.
Oh yeah......excellent job! Looks great Heeman. :eusa-clap:
Finally Done!
Looks Great Heeman! :handgestures-thumbup:
