Let your hair grow out.JeffMackwood said:Put everything back exactly as you had it before the new beasts arrived.
Find good places for the new subs.
Keep shaving your head.
:shhh:Babs said:I have felt the new subs!! IMO...my kidneys felt the thunder! Overall, more balance in the theater.
I watched & listened to several songs on the David Foster "Hit Man". So many songs I luv!!!!!!!!!!
Zing popped in " Live Free Or Die Hard" NICE!!!
Zing said:^LOL I'm doing my best to achieve that.
TrueRTA was giving me fits today. I very nearly launched my laptop through a window. So I abandoned that for now (because I don't want to buy a new laptop) and refined my by-ear adjustments with some assistance from my SPL meter. There are still some frequencies/notes that aren't hitting as hard as they did with my SVS but there are plenty of other frequencies/notes that are hitting harder. I don't know if that's to be expected or if there's something I can do about it.
On top of that, I'm not as thrilled with the symmetrical look as I hoped I'd be.
I knew the XS30 was smaller than my SVS but now that they're in place, I think it looks funny. Maybe I'll get used to it. Or maybe I should pursue my original intention of using the XS30's as speaker stand for my mains. I've currently got the subs as close to each side wall as possible and as deep into corners as possible to try and achieve the deepest extension. So I'm afraid moving them closer to the listening position will reduce the extension I'm looking for. DAMN YOU, RTA! :angry-cussingblack: These are the things I was looking for it to tell me.
OK, enough whining. Onto a legitimate question concerning calibration.
Most everywhere you look and most anyone you ask, you learn that you're supposed to calibrate all 5 speakers AND the sub to the same level. Now and then someone will mention the Radio Shack SPL meter's inaccuracies at lower frequencies and that you should compensate for it. I've pretty much adhered to the chart that SVS provided. The last time I calibrated, all 5 of my speakers were set to 70dB and the sub to 65dB. Now and again I would think that my sub was too hot. Regardless, I kept it that way. Strangely, when I recently mentioned that to TomV, he commented that he thought my sub was about 1dB too low. Interesting.
Anyway, I'd like to put this matter to rest. Do you calibrate all speakers and subs to the same level or do you compensate on the sub? If you compensate, how much?
I'm not unfamiliar with that chart. If someone wants to measure the output at a given frequency, they use their SPL meter and that chart. I'm looking to find out what level to calibrate the subs to. Do I set them at 1dB below the mains? 3dB? 4.5dB?? 6.014327dB?? What?Rope said:
What is it doing or not doing?Zing said:TrueRTA was giving me fits today.
Really? Then I should just calibrate everything to 70dB on my meter and deal with lower frequencies being louder?Flint said:So, the sub is calibrated to be the same level in its main operating range as the main speakers in the 100Hz to 200Hz range.
I wanted to start with a clean slate. Plus, my MobilePre somehow got its volume knobs turned down while it sat unused in the basement for the last year or or two. So I figured I'd better start with a Sound System calibration. No matter what I did, I couldn't get that "straight line" to appear. Finally, I gave up and opened a previous file thinking that the system calibration would still be valid. After a few Quick Sweeps, it was obvious it wasn't working correctly or reading accurately.DIYer said:What is it doing or not doing?Zing said:TrueRTA was giving me fits today.
Have you tried resetting to default.Zing said:I wanted to start with a clean slate. Plus, my MobilePre somehow got its volume knobs turned down while it sat unused in the basement for the last year or or two. So I figured I'd better start with a Sound System calibration. No matter what I did, I couldn't get that "straight line" to appear. Finally, I gave up and opened a previous file thinking that the system calibration would still be valid. After a few Quick Sweeps, it was obvious it wasn't working correctly or reading accurately.
Huh? I remember seeing RTA graph you posted couple years ago which showed the sub running 10 db too hot. :confusion-scratchheadyellow:Zing said:I find it interesting that all these years, I've had my sub level about 4-5dB lower than my speakers and still thought I was running it a tad hot.
Are you saying that you may not have needed those new subs? :think:It seems it's been 4-5dB too low.
I know! That's my point. That very graph you're referring was generated from a setup configuration of all 5 speakers set to 70dB and the sub set to 66dB. In fairness though, those 10 decibels were only in the 20-35Hz range. Everything above 35 was much flatter.DIYer said:Huh? I remember seeing RTA graph you posted couple years ago which showed the sub running 10 db too hot. :confusion-scratchheadyellow:
No, I'd never say that.DIYer said:Are you saying that you may not have needed those new subs?
