since i know nothing about headphone amps, i have to ask a couple of questions...
1. since your source would have a volume on it (mp3 player, cellphone), what would be the rule of thumb with the particular volume settings? if it comes with 15 levels, what should it be at?
2. when it comes to the amp, same thing, what would the rule be on the volume of the amp then? since you dont want to to be too loud as a source im assuming, your amp should be doing most of the hard work. correct?
3. of course, if theres a line level output, that would be the best to use to avoid any 'volume' issues, right?
on the way home i used my cellphone again to listen to some tunes, and love it. theres a sense of fullness to the songs i listen to. in comparison, when i listen to my music my volume is set at 13/15 based on the headphones i use (the ones from amazon that double as a headset), and et to listen to it where i can be aware of my surroundings and still enjoy it. its not 'in your face' kinda loud, but loud enough.
with the amp on, man, i had to put it on 9/15 i think, and despite being almost the same volume, i cant hear ANYTHING outside anymore. like im listening to some high quality set of cans.
i will end up using it later on this evening, after dinner, to enjoy it.. will tell you moe later on...
