Cut me some slack! You're creating these things in MS Excel on a Windows PC and sending them to a guy without Excel on his iMac. I don't think I'm doing too badly. :violence-torch:heeman said:Well that one didn't come out quite right, however I am sure that we can picture a rectangle 11' x 23.5'????
Zing said:Considering this is right up his alley, Flint has been suspiciously absent in this thread. Until he chimes in with his knowledge of proper room ratios, I'll say that you should likely be guided by prime numbers. An 11-foot width is a good start. So your length should be 17, 19 or 23 feet. The height is going to be a stickler because in keeping with the prime number theory, you'd then want a 7-foot ceiling.
As for the jog, I'm certain that will impact the sound, I'm just not certain to what degree nor whether it will be a positive or negative impact. If you have to have it, I might suggest rounding the outside corners. I don't mean a 1-inch radius bullnose either. I'm talking 6 or 8-inch hand-made radius.
Orbison said:Zing said:Considering this is right up his alley, Flint has been suspiciously absent in this thread. Until he chimes in with his knowledge of proper room ratios, I'll say that you should likely be guided by prime numbers. An 11-foot width is a good start. So your length should be 17, 19 or 23 feet. The height is going to be a stickler because in keeping with the prime number theory, you'd then want a 7-foot ceiling.
I think it's best to avoid dimensions that are (or almost are) even multiples of each other. So maybe 8 x 11 x 19 would be a good choice.
That is indeed best, hence my mention of prime numbers.Orbison said:Zing said:Considering this is right up his alley, Flint has been suspiciously absent in this thread. Until he chimes in with his knowledge of proper room ratios, I'll say that you should likely be guided by prime numbers. An 11-foot width is a good start. So your length should be 17, 19 or 23 feet. The height is going to be a stickler because in keeping with the prime number theory, you'd then want a 7-foot ceiling.
I think it's best to avoid dimensions that are (or almost are) even multiples of each other. So maybe 8 x 11 x 19 would be a good choice. Having said that, you could alternatively build the "jog" plan but fill in the extra width with shelves/eqpt/storage/etc - in effect giving you 8x11x19 usable floor space.
Zing said:That is indeed best, hence my mention of prime numbers.Orbison said:Zing said:Considering this is right up his alley, Flint has been suspiciously absent in this thread. Until he chimes in with his knowledge of proper room ratios, I'll say that you should likely be guided by prime numbers. An 11-foot width is a good start. So your length should be 17, 19 or 23 feet. The height is going to be a stickler because in keeping with the prime number theory, you'd then want a 7-foot ceiling.
