Deleted member 133
Guest
Where's the "jealous" Emoji when I need it!...when you were at the ATI factory...
Only the cool people get a field trip to the ATI factory/toyshop.Where's the "jealous" Emoji when I need it!
Was it my DORO flip phone?Only the cool people get a field trip to the ATI factory/toyshop.
That doesn't help.....Was it my DORO flip phone?
That is really strange. The transformer in the Monoprice version of that amp is no different than the amp it was derived from, and certainly not any less well made. The only "cost cutting" is having no XLR balanced inputs.So unfortunately it doesn't seem the CMX-2 is resolving my issue
I guess the amp has a defect, I'll have to call Monoprice.
As far as Parasound Halo amps, I would be looking at the A23. I know it's not a big deal, but would it seem strange to run the 2100 preamp (part of the New Classic series) with a Halo amp?
Those Dynaudio speakers can benefit from a very high current amp which can be pushed to its limits regularly and not fade from the task. I don't think you will get that from the Parasound New Classic amps and I don't recommend them for that reason. That said, if you were to tell me you generally keep the levels low, don't listen loud, and generally use the system for background music, I would not have recommended the Monolith amps nor the Halo amps. But, you don't give the impression that these speakers are for casual soft listening sessions.
That said, get the Halo, the A21 if the price is acceptable.
As for the idea it seems strange to use a Halo amp with the lower line preamp, that's nonsense. If I were to recommend a high end Krell amp or Bryston amp (both of which are great brands), would it seem strange to use that preamp with those big amps? It shouldn't.
The preamp is very good and doesn't need to be fancy or expensive to get the job done. The amp, especially with those specific speakers, would best service the job if it can handle constant high current, complex loads, and shine all the time. The preamp doesn't care about any of that.
So, don't think about "matching" product lines, as that has nothing to do with performance. If you can't wrap your head around it, get a Bryston or Krell amp. I recommend at least 150 watts into 8 ohms minimum for those speakers.
I've been trying to follow this thread, but one of the reasons I became a mechanical engineer was that I was too smart to do civil, and not smart enough to do electrical!On the other hand, another amplifier brand might have a transformer which isn't bothered either way by distortion on the AC line. This is just something you should be aware of.
